Read in Excel sheet tags via visual basic
Raiko
Hi all,
is it possible to read in the tags of the sheets in an excel work sheet? I'd like to populate a list box with the tags so that I can choose by clicking which sheet I wish to read in.
Has anybody some VB code that might be useful?
Thanks in advance
Raiko
MikeArmstrong
(To:Raiko)
Which script are you getting the error with? Push button or list box?
Mike
12 REPLIES 12
MikeArmstrong
(To:Raiko)
Do you mean the name of the worksheet within Excel?
Mike
Hello Mike
yes. The several sheets within one Excel file (i.e. tabs) are labelled sheet 1 to... Quite often I get Excel files with measurement data where these names have been altered (e.g. temp. reading 11...) so that I need to open the excel file in order to get the tab names. Any automation process on this task would help.
Cheers
Raiko
Knew that you'd answer first 😉
MikeArmstrong
(To:Raiko)
This sort of works, have a look.
I cannot find the code to do it fully automated, but this is a work around. I have used the function below within the excel worksheet to extract the tab name, and then called into Mathcad. It would mean whoever creates the Excel file doing a little extra work.
Have a look at both of the attached and let me know what you think.
Mike
Hi Mike,
thank's for the effort. I have a problem however with ActiveX. This is the error message I get when invoking your script
What's wrong?
Raiko
MikeArmstrong
(To:Raiko)
Forget the first proposal. I have sorted it. Save both files to your desktop.
Mike
Mike,
that works. Let's see whether I get the guys down in the basement to write down the tags on the first page.
Thanks again
Raiko
MikeArmstrong
(To:Raiko)
Thanks again
No problem.
They shouldn’t have to do anything extra. The second example is fully automated. All you need to do is select the Excel workbook and the scripted components should do the rest.
Mike
Mike,
I have encountered an error when opening the file (both files are saved to the desktop). Mathcad 15 M010.
P.S. Can be it is necessary to use in a script a relative path for file Excel?
MikeArmstrong
(To:Raiko)
Mike
Hello Mike,
I have this anoying problem I can't solve. Your code worked fine, but when I copied it into another drop list (in order to choose the tabs from that list) it refused to work.
Can you have a look at the attached MC 15 sheet and check what's wrong?
Thanks in advance
Raiko
MikeArmstrong
(To:Raiko)
Sorry for the late reply. I am currently traveling across Europe and don't have Internet access, except in the Hotel.
I'll have a look later for you.
Mike
Hello Mike,
no sweat. Take your time.
Here is a more advanced version. The previous one is faulty.
Raiko
