Reading in variable content into RTF text box
Raiko
Hi fellow MCrs,
I'm trying to display varying values in a RTF textbox. I'd like to pass over a variable to the RTF command line (as supplied by Samir Khan) and it is displayed with all powers and indicees in the proper place. Apparently, the command line does take the varibale name literally and instead of the variables content I get the variable name; see attached MC file (MC 15)
Does anybody with a deeper RTF knowledge know a work around?
Thanks in advance
Raiko
I've added a little string handling to create the text , I think that what you were trying to do probably worked in ver 11 (dependant on maple functions).
It works in a fashion on my machine (windows 7) but when I open the sheet all the text appears at the top left corner.
Insert a line before the RTFtext boxes & the text shifts into both.
A bug?? or does the RTFtext box need a trigger to reset it?
Andy
6 REPLIES 6
Can you disable the Scripted objects and repost the worksheet. I am having problems when opening.
Mike
Here you are
Raiko
Andy
Thanks a lot! It works.
Raiko
P.S.
I have the same peculiar behaviour on my machine (Win 7, 64 bit). Perhaps the graphic driver, because scrolling a page down and up again remedies the situation. Weird!!!
RichardJ
(To:Raiko)
I see the same thing under XP. Some sort of weird bug.
Incidentally, I am 99.9% sure that rtf text box came from Alvaro, not Samir.
Nice Andy,
This could come in very handy when writing programs in work.
Mike
