Hello to the whole community !!!
What to do to get the correct answer?
Thank you in advance, who will answer.
If I cannot swallow a large piece, then I cut it in half and swallow the two halves on a first come, first served basis.
Thanks, Valery.
Prime with new symbol engine
You could also do it this way:
Alan
If I remember correctly, we have seen this kind of bug already a few times here in this forum.
Usual workaround is splitting the integral, as Valery had shown.
Here is another (clumsy) workaround (which sure is not satisfying either):
BTW, this is one of a few rare examples where the new symbolic in Prime does better:
EDIT: Had not refreshed the screen for a while and did not notice that Valery also posted the new Prime symbolic.
I like the solution Alan came up with!
When all errors and flaws are cleared out of symbolic metamatics, then ... the end of the world will come.
Have you prepared for the end of the world?
Mathcad 11/Maple does:
