Community login and other support tools will be unavailable Saturday May 3rd 9:00 am to 3:00 pm (EST) due to planned maintenance. Learn More
Return a value form a table
BG_8835952
2-Explorer
Hi everyone, I have the following table as seen bellow in the attachment and my problem is that I have to extract alphax, alphay, betax and betay based on the value of lambda. Is there any way mathcad can do this on it's own?
Thank you in advance.
A little OCR on your table produces an Excel file data that can be cut and pasted into a Prime input table
Have shown the options to read the table from last four columns based on first column.
Capture.JPG.
(To:BG_8835952)
You may either use the "lookup" function -> Lookup Functions
or you even may use linear or spline Interpolation to also return values for in-between. lambda-values.
--> Linear Interpolation
--> Spline Interpolation
For further help you would have to attach your Mathcad or Prime worksheet (in case of Prime you also should state which version to use).
Thank you for your response!
Capture.JPG.
Thank you very much!
