SPF
ptc-4765498
SPF
this is mainly for A Westerman, but if you can help, thanks very much
,Hi Xavier
1 I would advise extreme care with equations like this.
In this case it doesn't evaluate but if it did you would be re-defining the metre unit for mathcad & everything after this would be compromised.
Later you do define g as stack(...) which redefines the gravitational constant that is used later.
2 I'm a little confused as to what you need.
F.w is defined as:
But then you re-define it with
Mathcad can't understand this recursive form so better to use the same format as you have for t2 & t3 earlier.
{Looking carefully I note that it is F[w*(j) not F.w(j)}
Now that i have corrected for the change of g,
F.w has units of kg/s^2 but you are trying to add something with units of m/s^2
There is an error here somewhere but without knowing what the equations represent it is difficult to identify what that error is.
Andy
