Saut de ligne
MartinBRUNET-di
Saut de ligne
Bonjour,
Je suis d�butant sur Mathcad et je souhaiterais forcer un saut de ligne � l'int�rieur d'une concat�nation.
Cela est-il possible?
Par ailleurs, y a t-il une m�thode pour zoomer/d�zoomer dans l'interface rapidement (molette et/ou clavier)?
Merci par avance,
Cdt,
Martin
10 REPLIES 10
Ce serait meilleur d'afficher une feuille de travail simple donc nous pouvons travailler sur votre probl�me. Juste montrez-nous votre cocatenation.
Les amiti�s.
Bonjour,
Je voudrais faire la concat�nation simple de texte comme ci-dessous:
<<br> toto:=concat�ner("-test1","-test2")
J'obtiens en texte:
-test1-test2
Je voudrais avoir :
-test1
-test2
Cordialement/Regards
Martin BRUNET
(I can write it in english if you want more details)
I have worked out the example you wished.
Regads.
Thanks for you help. Unfortunately, I have not been clear enough because that was not what I want.
I give you an example in the attach file.
Martin
You need to edit the script of the listbox to to the concatenation there.
Richard
StuartBruff
(To:RichardJ)
or add the line separation characters in the concat statement ...
Stuart
RichardJ
(To:StuartBruff)
Actually, I didn't realize Mathcad strings could handle them :">
Richard
StuartBruff
(To:RichardJ)
== Actually, I didn't realize Mathcad strings could handle them :">
By one of those marvellous instances of serendipity, I had used one of my string parsing functions to break an xml text up into lines earlier today (see http://collab.mathsoft.com/read?133200,63 ). The xml file uses the CR-LF pair to indicate a line-break, so the concept was fresh in my mind. (A Text Box needs both, BTW).
Stuart
If that is it. I disabled the first 3 commands and the following text did not disappear. So the workheet is a parsed text. I don't know how this can be incorporated into a MC11 sheet.
What's the use of the submitter's request anyway?
Thanks you all for you help.
Martin
