Scalable vector file
JH_9781973
8-Gravel
Is it possible to export out a scalable vector file from Mathcad prime worksheet? If yes how can I do that?
There is no means built specifically into Prime to construct and save SVG (Scalable vector graphics) files.
SVG files are simply text files so it is possible with a bit of work to construct a matrix of SVG text and save this with Prime function WRITETEXT to an *.svg file..
Cheers
Terry
5 REPLIES 5
Hello @JH_9781973
Thank you for your question.
I'd like to recommend to bring more details and context to your initial inquiry
You could add details like:
  1. Have you tried any methods or tools so far to achieve this? If so, what were the results?
  2. Could you share more about the content of your worksheet and what you aim to export?
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Vivek N
Community Moderation Team.
Cheers
Terry
Have enclosed extra function that deals with the quotation marks
Hello @JH_9781973
It looks like you have some responses from a community champion. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
