Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Script to create dropdown menu in Mathcad 14, that imports data from excel file
AbrahamBorg
I need to find a way to create a drop-down menu in Mathcad that grabs material properties directly from an Excel file, and plugs them into the mathcad workspace. Could someone please point me in the right direction so that I can try to figure this out. I have attached a picture of what this dropdown menu might look like in Mathcad. The other attachment is a sample Excel file that would contain the material properties. Thank you, any help would be greatly appreciated.
18 REPLIES 18
RichardJ
(To:AbrahamBorg)
Your jpeg shows a picture of Mathcad Prime. Mathcad Prime does not currently support any kind of component such as list boxes. Are you committed to Prime, or are you free to use Mathcad 15?
I am not commited to Mathcad Prime. I am currently using Mathcad 14.
RichardJ
(To:AbrahamBorg)
Somerthing like this?
Hi!
This solution was exactly what i was looking for.
The only thing I wonder is how to output more values.I'm working on a mathcad-excel combo where the excel fil contain all nesscessary information about standard reiniforcement properties. Like area, diameter, etc..
So long so good. I manage to show them seperatly, but... I would like to have all values written out when I select feks B500C Ø12
That means that I should not need to enter the property list. When I choose the reinforcement all data is listet and is automaticly used by further calculations.
MikeArmstrong
(To:AndreasHV)
Can you post both worksheets?
Mike
Hi!
I managed to get seperate outputs but when I extend the Datarange in the reinforcementNames from 8 to 9 I get a fautl code.
MikeArmstrong
(To:AndreasHV)
Have a look at my example below. It is much easier if you embed the Excel component with Mathcad.
Mike
great.
But also get the same error when changing from submatrix(data,3,8,0,0) to submatrix(data,3,9,0,0) or abow.....
"This array has an incorrect number of rows and columns"
MikeArmstrong
(To:AndreasHV)
See attached, I have modified your sheet and it looks much simpler.
The reason your getting an error is because you only have 9 rows in your data and your trying to go above that. You need to increase the Excel worksheet first.
Mike
I've tried to insert 20 more lines but It won't work out. Still get the same error message.
Weired...
MikeArmstrong
(To:AndreasHV)
Use this sheet. Remember you need to change the Excel worksheet.
Mike
This is very helping, thanks a lot.
But I am still A beginner for all of this and it would be very nice if you can help me to get more senses. Please see below.
1. what does "+3" or "+1" of steel +3, property+1 mean? I can glimpse that is for an order but not sure.
2. Is that possible to have it syncronized? for example,
when material A and B have different properties from each other,
Choosing material A, and submatrix for property shows only the applicable properties for material A.
- and this has several chains..
(Material A: Size 1 ~ 12, Frequency 1 ~ 15, Density 1 ~ 5)
(Material B: Size 1 ~ 8, Frequency 3 ~ 20, Density 1 ~ 5) something like this...
Any chance for this?
(mathcad 15 and prime 3.0 are available)
Many thanks,
MikeArmstrong
(To:SKim)
This is an old thread. I suggest you create a new thread with your problem and we can work from there.
24-Ruby V
(To:SKim)
As Mike already said - open a new thread with your specific question.
In the meanwhile - you may also be interested in Tom Gutman's famous AISC steel shapes sheet.
Unfortunately PTC was incapable to move the postings from the old collab to this forum here correctly, so the only link I could find was this: http://communities.ptc.com/message/156420#156420
MikeArmstrong
(To:AndreasHV)
Have a look at the attached.
Mike
Hello!
How many types of steels you want to have in the document?
MikeArmstrong
(To:VladimirN)
Hello!
What difference would that make?
Mike
MikeArmstrong
(To:AbrahamBorg)
There are many different ways this can be achieved. I usually embed an Excel sheet within my Mathcad worksheet and hide it if it is not meant for display purposes.
Insert, component and select the Excel component. Then the data can be called from within your Mathcad sheet.
Mike
