I want to take select elements of one array and use them to initiaize another I am subsampling an array. For example:
i = 0;10
A=i
B=[1,3,6]
Now I want:
C[0] = A[1]
C[1] = A[3]
C[2] = A[6]
Of course for my real case the arrays are very large.
Is there a simple way to do this similar to matlab, using arry B to index into A? At this point I have to use a program but I expect there is a nice way to do this with something like C= A[B
Fritz
You're very close. ORIGIN in mathcad defaults to 0
Thank you Fred. I had a syntax error in my "subscripts of subcripts" and your example helped me to figure it out.
Cheers!
Fritz
