Setting up CreateSpace correctly?
pquint
2-Explorer
Greetings,
I had created a test document to practice the CreateMesh and CreateSpace functions.
This was done on one machine with Mathcad 15.
Now, the CreateSpace will not  display on a different machine which also has Mathcad 15 and Prime 3.1.
Any ideas as to why?
If nothing is wrong with the set-up, what settings could make this behavior happen?
The file is attached.
Thank you for your time.
P. Quint
VladimirN
(To:pquint)
Right click on 3D plot (created by using "CreateSpace") and deselect "Border".
It might be a problem with the monitor set-up,  I took the following snips from the same laptop just set either for 16bit or 32bit colour resolution.
regards
   Andy
VladimirN
(To:pquint)
pquint
2-Explorer
(To:VladimirN)
Thanks VladimirN.
I don't know why that enabling the border messes with the display, but yeah.
Mark
VladimirN
(To:pquint)
You're welcome.
Peter Quint wrote:
I don't know why that enabling the border messes with the display...
The problem with the border for 3D plot - it is an old story.
