Shifting Matrix/Vector in Mathcad
Mathcad111
11-Garnet
Example:
Like this:-
Cheers
Terry
11 REPLIES 11
Like this:-
Cheers
Terry
Hi, this method is not working for -ve values and floating values in 'D', Pse suggest
Eg: D=(0 1 -2 0)
Eg: D=(0 1.5 -2 0)
Can you please provide an original "S" matrix and a Resulting matrix "Res" when you use a negative whole number in "D"?  I imagine this means a rotation of "S" values downwards in that column?  Can do this.
Can you please provide an original "S" matrix and a Resulting matrix "Res" when you use a floating value in "D"?  Not sure what this means?
Cheers
Terry
terryhendicott - 'I imagine this means a rotation of "S" values downwards in that column?' - Yes
terryhendicott -'when you use a floating value in "D"?  Not sure what this means?' - ok just for now, we will avoid/omit this requirement, let only focus on '-ve' values
terryhendicott -'Can you please provide an original "S" matrix and a Resulting matrix "Res"', - currently I can't, i'll work on the same shortly.
Pse check below attached,
Tried this method but its not working, PFA.
Hoping this is what you are seeking:-
Cheers
Terry
Thanks lot for response, i'll check the same.
LucMeekes
(To:Mathcad111)
Note that with a matrix of 4 rows, shifting 2 or -2 is the same.
Shifting a matrix over a non-integer amount of rows is not obvious. How would you define it?
LucMeekes
(To:Mathcad111)
OK, here's an implementation that takes an approach also for non-integer values of the 'number of elements to shift':
Works also in Express.
(Prime 4 file attached)
(To:Mathcad111)
Her are my 2 cents
