Show String of max load combination from the max function
Digger28
I want to be able to show which load combination was chosen from the max function in order to make it easier for people to see which load combination was chosen for the design strength. I would like to be able to use a text box for this, but if that is not possible then that is fine.
(To:Digger28)
Accessing the names of variables is not possible, I think.
One way I can think of is to put all the values in one vector and all the names tyoed in another. Then use the match() function to get the index of the first occurence of the maximum.
Its cumbersome.
Once you have the text you want to display, you may display it in a textbox as well.
