hello,
I want to simulate a program such that two conditions must meet at the same time to run the program. I saw Mathcad does not have a "and" statement. Please help me out with this. I have attached my file. My version is prime 4.0.
Faisal
Mathcad (and even Prime) definitely HAS an "and" statement!
But of course you could nest two if statements with else to get the same effect 😉
I don't see it in my Prime 4.0. I even tried in resources but it was not there
In the meantime I attached a picture to my post above which should make it clear.
BTW, for the example you posted you don't need any "And":
Thank you very much. It worked
