Single element matrix?
RadovanOmorjan
I hope this is not posted before (I doubt). Is this correct? I think a*b should be matrix not scalar. This is also in Mathcad 14.
Radovan
5 REPLIES 5
It's the product of two single element vectors, and the behavior is exactly the same as if they were two two element vectors. Which is what I would expect.
Richard
>I would expect.
>Richard
Yes, you are right. Product means here - "scalar product of two vectors" - the result is scalar.
Scalars, Vectors, Matrices and product operator - three different things.
I forgot that, sorry 😞
Radovan
A long standing issue, and a result that is different in different versions of Mathcad.
The problem is lack of a proper distinction between vectors and matrices. A one element array can be equally viewed as a one element vector or as a one by one matrix. If it is viewed as a one element vector, then the product is the vector dot product and properly a scalar. If it is viewed as a one by one matrix then the product should be a matrix product, another one by one matrix. I have sheets that work with variable sized matrices (depending on the data) and need to have the limiting case of a one by one matrix handled as a special case because of this odd behaviour.
__________________
� � � � Tom Gutman
You are quite right. For instance, in one Mathcad version you can not define a variable as 1x1 matrix/vector, but the result of calculation could be a 1x1 matrix/vector - what to say? On another version of Mathcad - different behaviour. Quite confusing.
Radovan
I have used a 1x1 multiplied by a 1x1 as
a practical problem using Fortran. Therefore,
I recommend that PTC considers this Fix.
Julio C. Banks, MSME, P.E.
