Solve 2 equations
kenan2
Solve 2 equations
How can I solve for teta.
(To:kenan2)
Use a numeric solve block and solve for theta AND F.N.
It might be helpful to add a constraint like 0<theta<pi/2.
Its the very same as shown here: https://community.ptc.com/t5/PTC-Mathcad-Questions/Solve/m-p/559677/highlight/true#M181249
(To:kenan2)
kenan2
(To:Werner_E)
Thx very much I think I know how to solve these equations know! 😄
Is solve block the best way to solve 2 equations with 2 unknowns ?
Fred_Kohlhepp
23-Emerald I
(To:kenan2)
We have been taught that you must have the same number of equations as you have unknowns or a problem will not have a unique solution.  Many problems ((your theta problem, for example) can be solve by simple algebraic manipulation.  (You use one equation to eliminate a "variable" (Fn) from the second, leaving only one variable and constants.
We later learned that there was a matrix form of this that would solve it.
There are, however, forms of equations that resist/defy manipulation like that.  For those situations we can use a solve block, and let Mathcad employ proven optimization techniques to find the solution.  So you may use a solve block to solve all 2 variable/2 equation problems; but that does not mean it's always the "best" way.
Fred_Kohlhepp
23-Emerald I
(To:kenan2)
How about a little basic high school algebra and trig?
