I have a problem with my solve blocks in both Prime 2.0 and 15 that I was hoping someone might know how to solve.
I was trying to follow this nice example (example on left, my work on right), but as you can see, once I get to the givens, the expression gets evaluated on the right side before I have a chance to enter the value it's supposed to equal.
I couldn't find this mentioned in any of the solve block tutorials (for either prime 2.0 or 15). Does anyone have a suggestion to how to fix this?
You can't have two solve blocks side by side in MC15 unless you put at least one completely in a text region.
For further questions please attach you worksheet as usually its hard to impossible to debug a picture.
As you have noticed you can't simply copy and paste a picture in the text. But you could have edited your original post instead of posting an additonal one.
You have the first 2 types of equals for mathcad.
1 := the assignment
and
2 = the evaluation
Now for the solve block there is a third
here you need to use the 'boolean equals' = and in the work sheet it will show up in bold.
this doesn't define values, but rather the relationship between variables.
It can be typed as "<ctrl> = "
or selected from the boolean toolbar on the menu at the top of the mathcad window.
Regards
Andy
Don't bother with Prime 2, it's nearly worthless unless you're trying to learn the editor.
See version 15 attached.
Remember Mathcad evaluates left to right and top to bottom.
