Solve Function
SPRstructur
Solve Function
Dear All
I am stuck here. I can not find any method to solve the solution of function like below, help me.
The goal of this sheet to find solution X and we have function and many variable. And variable will input below.
If you have any methods to solve this problem please.
Big thank.
1.Function
2.Data Input (below function)
(To:SPRstructur)
Would turning the solve block into a function help?
LucMeekes
(To:SPRstructur)
Prime complains in the solve block, because x is undefined. That is correct. It is only defined after the solve block, not before. Note that Prime reads left to right, and top to bottom. And for a numeric solve block, ALL used variables MUST be defined beforehand.
The solution is simple. Move the solve block (out of the area) to a location below the definition of x (and all other variables). Then you get:
I hope that answer corresponds to your expectations.
yes Meekes correct answer ,
but I need it as function also because in the future I need include/link to another file
(To:SPRstructur)
SPRstructur
(To:Werner_E)
Great Werner_E
