Solve Non-linear System - EOS Critical Conditions
mnori
Dear All,
I would like to receive clarifications about the solution of a nonlinear system through the use of a solve block Given/Find. In the attachment it is reported the  system that make use of the symbolic derivative operators ( EOS isothermal inflection point- critical conditions ) . The solution converges only up to a certain value of the input parameter ( epsaa, Vaa ).  Any suggestion how to solve this issue?
Your sincerely,
Massimiliano
LucMeekes
(To:mnori)
You're trying to solve the system for T=Tc. See what that does to the value of the Covolume Soft-core parameter:
You may get a division by zero.
Further:
I tried to solve the set symbolically (with part of the parameters defined)
and after 30 minutes it found no answer.
Hope this helps.
mnori
(To:LucMeekes)
Hello Luc,
The system has three unknowns ( εc,η  and bc ) in three equations. As shown in attachment, the Solve Block is solved only up to a certain value of εaa and Vaa ( EOS parameters ).
  The equation you considered added a further variable : b.
