Can I use solve block inside a program loop? For example, it may be useful if I need to scan all the possible solution of Find(var1,var2,...).
Many thanks
S
You can use the find function in a program. The Find function can be parametized as a function and you can call that function in the program. Enclosed is a file example that shows how to do this.
Cheers
Terry
Hi Terry,
Thanks a lot!
