On my calculatur, this is so easy, so way can't I get this right.
Is there any standart way to solve I can use when I am not solving a x,y funktion?
Mathias.
Inside a solve block, first specify a value for delta_isolation using ':=' (set it to, say, 1mm).
Then set U = the expression involving the deltas etc, using the '='.
Then set delta_isolation := Find(delta_isolation)
Alan
PS Can't give you a corrected worksheet as I don't have Prime 1 installed at present.
Alan
Please provide a PDF version of your Mathcad Prime worksheet.
Didn't think of that Vladimir! See attached (rather a large file though).
Alan
Thank you, Alan. I asked about this, because right now I do not have access to Mathcad Prime.
AlanStevens wrote:
...rather a large file though...
I think it's because the picture is inserted into the worksheet.
@ Alan
Thanks AlanStevens you ware really a big help.
I atach a PDF as well as the workingsheat(problem solved), to help others with the same problem.
