Hi
I write a new calculus sheet, with it, i want to calculate a kinematic for parallel glide structure( is it a Clavel's Delta robot variation)
In my sheet, i don't understand why prime don't solve the last equation
see attached file
Anyone can help me ?
The reason is that OP.i is a matrix and so is the RHS of your equation!
If you clear OP.i (and L) for symbolic calcs, you get a symbolic result
Great ! ( i don't know clear function.)
It is possible to use it in program for calculate all value for
B1_z ; B2_z ; B3_z
I need to calculate it for each leg
I don't know to make it in one program. I want this program give me B1_z ; B2_z ; B3_z for control robot
Another question:
it is possible to keep only positive root, and , it is possible to assign this solve result to a new variable ?
@XDN wrote:
Another question:
Yes, it may be possible to return the positive root alone but it will require a couple of "assume" modifiers because the symbolic has to be told if the variables you are not solving for are real, positive, etc.
And yes, you may assign the solve result to a variable, better yet to a function!
whow !! i don't know how to do that🙄
The result depends on eight input variables
A.ix,A.iy,A.iz,O.x,O.y(is missing, is this a typo?), O.z, OP.i and L
You may assign the symbolic solve to a function with those eight arguments.
Ok
But i don't know to make it.
I try to explain my problem, certainly i'm not clear, sorry for this.
I have a vector problem
In this picture
I have 3 linear actuator :
The Ai points are fixed ( i know each Ai) , the Bi point are moved. More presicely the Bi point moving is only on z axis (xy value for Bi point is know, and they are xy value from Ai)
The C point is the point of interest.
And is this point to move.
When i want to drive this robot, i give C coordinates (X,Y,Z) ( I make the inverse kinematic model)
And, C points coordinates values are know.
I know by building the L parameter , L is the standard vector ||BiPi||
And after that i calculate the kinematic close loop with vector, as in my sheet
Is that i want to use symbolic function in Prime
And finally , i want calcul the displacement parameter along each linear axis
This parameter is only Bi coordinates along z axis.
And after i drive my motor with this parameter.
Sorry, i'm bad in mathcad use ...
I don't know how to do it, for realise your idea
Sorry, I don't know how to set up your kinematic problem.
I had not looked at the rest of your sheet, just at the last solve region to see why it didn't solve.
Do not be sorry,
I try to explain my kinematic problem for a global view
The kinematic, is not problem.
My problem is write equation in Prime with progam function using.
May be the study 8 from the book
2^5 Problems for STEM Education
will be useful for you.
See please animations from this study
Ok
I want to learn Mathcad ( i buy your book now )
@XDN wrote:
Ok
Thank you!
One part of the book is free
