How can I solve this? I just can't get it to work.
Hi Mathias,
You just need to correct the units for your initial guesses.
After that it works fine
regards
Andy
Hi Mathias,
regards
Andy
Thanks!! Matchad is new to me, so I didn't know if the setting of the solveblock was wrong. Bot as you write, the unit's is the fault in this one. ![]()
