Solving for Intersections within a For Loop.
abissett
Hi MathCAD Community,
To start I will try and give some background to the problem:
I have imported some data points that represent two edge curves of a surface in Creo. Using Matricies I can rotate these data points by a given angle made up of Yaw and Pitch. I then project these rotated data points to the zero plane using a projection Matrix. Next I fit a function through the two sets of transformed data and using integrals I calculate the area between these curves.
Now that I have worked out how to do this by specifying the rotation angle I want to iterate through 180 degrees of rotation in Yaw and Pitch to find the orientation that provides the smallest area between the curves.
My problem is when I go to find the potential intersection points of the two curves (for defining integral limits) I use a solve block, which cannot be implemented within a for loop for iterating through angles...
If anyone could help me find a solution to this ASAP it would be greatly appreciated. I have attached my methodology for completing this without iterating through a For loop.
Dion
The general approach to this kind of problem is to make the solve block a function of the variables you want to vary.  Please see the attached worksheet.  Unfortunately, it means propagating those function arguments back through the worksheet.
Sorry about the layout of your worksheet ...
Stuart
This document was generated from the following discussion: Solving for Intersections within a For Loop.
Sorry I'm not sure I follow completely. I understand what you have done but then how do I iterate through the whole process if the solve block still cant be used within a for loop?
StuartBruff
