Solving of spice netlist using Mathcad prime 5.0
BB1
Is there any way to generate the voltage and current equations from spice netlist using Mathcad prime 5.0??
6 REPLIES 6
(To:BB1)
It may be possible to do so.
You would have to write a program which reads in the spice file and parses it. Looks like a lot of work.
Guess that calculations would only be possible for simple circuits only, though.
terryhendicott
(To:BB1)
LucMeekes
(To:BB1)
While parsing of the input file may be doable, to actually calculate voltages and currents in a given circuit requires much more. You have to have models and their parameters. Note that models differ between when you do an AC simulation or a TRANsient. If you want to be able to tackle any spice input deck, your effort will be huge, and given the fact that PRIME is not a programming language (!) I think you better crack another nut.
This is not to say that it's impossible to calculate electronic circuits, in time or frequency domain.
For a small example:
mvenich
(To:BB1)
There's no tool in Mathcad to do this. But there's a free addon for Maple that turns a netlist into equations
https://www.maplesoft.com/applications/view.aspx?sid=127001
BB1
(To:mvenich)
Is there any add on for the Mathcad prime like syrup for Maple??
LucMeekes
(To:BB1)
Mathcad from version 4 through 13 uses/used Maple as the symbolic engine. Starting with Mathcad 14, and on to Prime 5 the symbolic engine is MuPad.
So: You cannot have Prime use Maple.
If you want to use Maple, buy Maple...
Success
