Suppress Symbolic Solution in M15
StuartBruff
23-Emerald V
I don't know if this has been noted before, but I managed (by accident) to suppress the display of a symbolic solve in M15 [Mathcad 15.0 (M030 [MC15_M030_20131216])]
Does this work in other versions of Mathcad?
Stuart
37 REPLIES 37
-MFra-
(To:ifomenko)
I think that, in addition to the round brackets, the symbolic equal is not really needed.
ifomenko
(To:-MFra-)
Yes, but I don`t need symbolic result which takes half of the screen and it takes time to make visualization.
Please look at my code I try to speed up some calculation. Symbolic calculation of functions improve performance but I can`t suppress symbolic results because the last function can`t be solved symbolically (:
-MFra-
(To:ifomenko)
It seems to me that your worksheet is overflowing with useless symbols such as subscripts with round brackets and in others the braces. The indices of the indicated variables do not go in brackets; did you invent this ->{ξ} ?, staples are not needed. ξ is an undefined vector.
ifomenko
(To:-MFra-)
ksi and {ksi} are the same, don`t worry about this, I use {a} for vector, [A] for matrix, if expression is very big I have to remove {} to reduce size of expression. The problem of my worksheet is the last expression can`t be done symbolically so I can`t suppress previous symbolic results as you and Werner suggested.
prop_design
(To:ifomenko)
hi,
i may not understand completely what you are trying to do. but doesn't cntr = yield a bold equal sign. then whatever you type is just reference notes. i use that a lot to make documentation. nothing gets solved in that case. i do wish there was a proportional sign though. for that i have to fake it completely. type a variable then next to it put the alpha symbol then next to that type the equation. so it looks like what i want but nothing solves.
anthony
ifomenko
(To:prop_design)
Everything must be solved, to improve performance I want to calculate functions symbolically but hide results. I need only the last expression which is numerical, it can`t be done symbolically. So, if I use bracket trick for all symbolical expressions I can`t get result for last one because, as I`ve already written, it can`t be done symbolically. So I have all input function for the last expression in red.
-MFra-
(To:ifomenko)
Hi-
in the definition of  [dξ/dX].TRI2D6.f - you divide by J.X/ξ.ξ.f - but it is undefined. I think that it is the source of the delay calculations.
ifomenko
(To:-MFra-)
It`is not undefined, it`ll be passed to dksi/dX function as argument. Thank you and others. I understood the situation with this task. Don`t worry .
