Symbolic matrix construction
JuFlo
I try to create a symbolic matrix (in my example, the matrix RES  ).
The problem is that I cannot have the result in the form of a matrix, the only way to obtain what I want is to say that RES is not a matrix and is depending on two others variables corresponding to the indexes of the "matrix" (RES2 solution in the attached file question.xmcd). However, I need to use this result after and I need to have the result in the form of matrix.
How can I do to obtain my result in the form of a matrix ?
Thanks !
1 ACCEPTED SOLUTION
You cannot index a function at its definition.  Mathcad is looking for the name of a variable to index.
The second function definition does work as it does a number of summations that return a single value as a result of the function.
You can define a matrix that uses this function.  Is this what you are after?
Warning.  by default Mathcad indexes matrices from 0,0 unless you redefine ORIGIN worksheet variable.
Cheers
Terry
9 REPLIES 9
Cheers
Terry
JuFlo
(To:terryhendicott)
Thanks for your response !
The answer would not be complete now we know the intent.
You can define the matrix with a quicker notation using the values of r and s you defined.
In this case a name is used in the definition so you can use indexes
Remember by default matrices start at index zero.
Cheers
Terry
JuFlo
(To:terryhendicott)
This is exactly what I wanted, thanks !
But I still have a question, if I want to keep U and V as symbolic variable, the only way to obtain the matrix is to create each component "manually" as in your previous response ?
JUF
Not sure I understand your question.
U and V are variables in scope for the function RES2 definition.
V is also a variable in scope for function MAT2 definition.
I don't want to call them symbolics as this has another description in symbolic arithmetic.
U and V in definition for RES2 are set to  the values 10 and 31 only in the definition of the final matrix in one statement.
JuFlo
(To:terryhendicott)
I want to have this :
where MAT(U,V) is a matrix (of function) and U and V are variables in scope for the MAT function. After, I will used this matrix for different values of U and V but for now I want keep U and V as vrariables.
My question is : can I do something like the print screen below?
Or do I need to define each component of the matrix MAT as it's done in the previous printscreen ?
JuFlo
(To:JuFlo)
(There is the reply with printscreens, sorry)
You cannot do this as Mathcad will not let you define a function with index values.
You either do as in your matrix method which gets cumbersome with big matrices..
Or use a small program to get around it.
Cheers
Terry
JuFlo
(To:terryhendicott)
The solution with the for loop works perfectly  !
Thanks a lot Terry, It's really helpful.
Cheers,
Julian
