Symbolic solution for a system of symbolic equation
swasterlain
Hi there,
I'am a new user on Mathcad software and i'am getting stuck on a very simple problem, which i can solve manually, but i want to practise a bit with Mathcad.
My problem is the following, i got two symbolic functions called C1 and C2 in my worksheet, which i want to be equal to zero (each of them). My two variables are Ti and Tn. When i tried to solved those equation i got an undefined solution.
Thanks to tell me where i'am wrong.
Sébastien
9 REPLIES 9
(To:swasterlain)
You can reach a wider audience if you additionally provide a screenshot or pdf print of your sheet, as many of us did not bother upgrading to Prime 3.1 and so cannot read P31 files (just P30).
VladimirN
(To:Werner_E)
Werner,
PDF version of this worksheet in attachment.
May be so
Hi Werner,
Next time i will do that, thanks.
Hi Valery,
Thanks a lot. Mathcad is intransigent about syntax. Are there some "books" about syntax in Mathcad ? I was looking for your solution about one hour on google without success.
Thanks again
Sébastien
Thanks! See please The parts of book of Valery Ochkov
I use in Mathcad only solve, substitute, simplify, coeff and a couple others symbolic operators.
See please Study 6. Symbolic mathematics and 3D-graphics in thermal engineering
When I need more I use... Maple
Can you please tell me how to get value of omega in the below snip.
You should always post your mathcad worksheet.
I think your units of m1, m2 are wrong, or those of k1 and k2.
But apart from that, how's this:
I recommend to you a book by Brent Maxfield "Engineering with Mathcad":
Essential Mathcad for Engineering, Science, and Math w/ CD, Second Edition
Essential PTC Mathcad Prime 3.0
Valery, Vladimir,
Thanks a lot for your recommendations .
Sébastien
