"I have been looking into using Mathcad to solve 1st and 2nd order ODE'S symbolically".
____________________________
The linear 1rst & 2nd order solvers have been designed and posted many times in this collab, but can't retrace at the moment. As long as the forcing function has a Laplace, then the two solvers works fine. For variables coefficients, you should refer to their formal solution. There is also the Frobenius solver in the collab.
jmG
