Symbolic value propigation
creed-2
Can a variable's symbolically obtained value be propagated to future uses of that variable?
I want my second expression to see c2 as zero.
RichardJ
(To:creed-2)
Use a numeric assignment with the symbolic solve:
To attach a file click on "Use advanced editor" at the top right of the edit dialog (it's not very obvious!).
6 REPLIES 6
(To:creed-2)
Maybe that way:
There are sure other ways but you have to be more precise as to what you are really after at at the end.
Looks you have to solve a system of equations?
Next time please attach your worksheet, but as you are using Prime, you still have to provide a picture or a pdf printout because many of us (like me) cannot reat P3.1 files with our P.3.0 version of Prime.
WE
RichardJ
(To:creed-2)
Yes, but not like that. The symbolic evaluation gives f''(0) as c2. The boolean equals and the 0 have no effect at all, they are just cosmetic, so c2 has not been assigned any value. The only way to assign a value to a variable is with a numeric assignment. That can be coupled with a symbolic operation, for example a solve, but in your case I can't tell you exactly what to do without seeing more of the worksheet.
creed-2
(To:creed-2)
I've attached a simplified example of my question. If I want to use "x" later in my worksheet I have to redefine it after it's symbolically solved.
If my "y" or "w" variables change, the new value for "x" is no longer propagated.
Is there a technique that would keep me from refining "x" every time is value is effected?
*I'd add an attachment of the original file but am not seeing an option to do that, what am I missing?
RichardJ
(To:creed-2)
MJG
18-Opal
18-Opal
(To:creed-2)
append "x:=" to your equation that solves for x:
P.S. to add an attachment, select "Use advanced editor"
MJG
18-Opal
18-Opal
(To:creed-2)
Perhaps you could use this general solution to your original post:
Or, if w & L are previously defined, you could use this case-specific form instead:
