I've done a short programblock, where the result asa text is assigned to a variable.
Simplified like that:
text:="Results er ok."
Now is it possible to just show the result of the variable "text" in the worksheet without showing "text="?
Three possibilities come to mind:
1) put an empty object (e.g. "Insert/Picture") over the part you don't want to see
2) use symbolic evaluation and hide the LHS (you will still see the right arrow or an equal sign, though)
3) use a scripted component to display the text. Here you could also change the fore- and background color of the text depending on the result
I am assuming you are using Mathcad 15 (or below). Otherwise in Prime 2) and 3) will not be available and I am not sure about 1).
Forgot to mention that I am using Mathcad Prime 3.
Sorry, my tricks only in Mathcad 15.
So the only way I can think of is placing a piece of white bitmap over the LHS - not exactly an elegant solution.
I just tried and it works. Its crazy but I found no way to change the order of the regions, so whatever is placed last is on top - in case of the following example its the first text evaluation.
I insert different pictures as a text by the changing of languages on my Mathcad server.
One example.
http://twtmas.mpei.ac.ru/mas/Worksheets/Chem/Surface_Tension/isotherm_surf_ten_ERU_new.mcd
And I do it when I want to have comments - all is ok or not ok - with colors
