The Three Reservoir Problem Revised In Prime
MBuck2
I converted an old Mathcad 12 template to MC Prime 2 see attached but for some reason the solve block is not returning a solution. Can anyone see the problem - is it something to do with units or has the solve block been set-up incorrectly for Prime?
Regards, Mark
AlanStevens
(To:MBuck2)
Have a look at the attached.
Alan
10 REPLIES 10
VladimirN
(To:MBuck2)
Hi Mark,
Can you upload your instant worksheet for Mathcad 12?
Vladmir;
That's my problem I cannot find the original version 12 file. I converted this some time ago and it would appear that I have changed some key aspects from the original but the methodology looks sound to me.
(To:MBuck2)
Mark Buckton wrote:
Vladmir;
Could it be the one of yours in this thread?
http://communities.ptc.com/message/30412#30412
MBuck2
(To:Werner_E)
No that is still not the original file version 12 file that is an altered version that I was playing with but never completed.
(To:MBuck2)
Just thought as that old file show the same error of Z.i not being functions as your Prime worksheet
AlanStevens
(To:MBuck2)
Within the Solve block shouldn't ZA be Z(QA), ZB be Z(QB) etc?
Alan
Alan;
What you suggest is logical and I have done what you have suggested but now Mathcad is complaining that Ep needs to be a function but a function of what? It cannot be a function of flow rate as there are 3 independent flow rates? Any more suggestions?
Mark
AlanStevens
(To:MBuck2)
Alan
Alan;
It appears I done what you had suggested but there must be a typo in my sheet - somewhere. Thank you. It now seems that the answers (flow rates) that are being generated are not plausible but that is another matter which I am now investigating,
Regards, Mark
(To:MBuck2)
Mark Buckton wrote:
Alan;
Mark
You probably forgot to change Z.A for Z !?
