The element in this vector must be in ascending order - interpolation error
Cornel
ttokoro
(To:Cornel)
In this cace linterp function has no meaning to show the sine wave at high frequency.
7 REPLIES 7
Cornel
(To:Cornel)
Post deleted by the author
Cornel
(To:Cornel)
Stop beating with this thing at this moment. I discovered something I don't like in the dataset at high frequencies points. I need to review the dataset.
ttokoro
(To:Cornel)
Cornel
(To:ttokoro)
How to eliminate data points with yellow? So I want to remain only with data from 1/freqi.
Cornel
(To:Cornel)
So, only this portion to remain, which is 1/freqi (1kHz in belowe example) portion
But right now I modified manually the range of x axis, below value
Cornel
(To:Cornel)
For example:
Adding them
And now I need to extract data points from below vectors:
but only data points corresponding to the length of from:
ttokoro
(To:Cornel)
image.pngimage.pngimage.pngimage.pngimage.pngimage.pngimage.pngimage.pngimage.pngimage.png
