Both inputs are define and their values are shown below. Requesting a solution to this error.
Unfortunately, I am unable to attach the worksheet. However, I found the mistake. The error was caused by a previously defined ey and Sy. Thank you!
Requesting that you attach the worksheet.
Your picture, while it may be telling more than a thousand words, is telling only part of the story.
