After increasing array size of t the variables getting undefined. Help me please. Im very new to the MathCAD. Error occurs on MatchCAD15
If n<= 10 then all works fine. But i need it to be 25
You may consider changing the value of E0 to avoid the division by zero!
Attach pls Mathcad-sheet!
I attached two sheets, the one that is working, and the one that is not.
Thank you!
