I would like to use in my Prime-sheet time units ns (nano-) or ps (pico-) from the list of built-in units but:
Is it a bug?
Found it.
The unit system is set to CGS. If you set it to SI, ps and ns are defined
No problem here with Prime 3.0.
I can type the units manually or chose them from the Units menu - they always work as expected.
Hi Valery, Werner.
It's a bug in 3.1, I have ns and ps undefined too.
Best regards.
Alvaro.
In my Prime 3.1 express the 'ps' works, and can be chosen from the units menu.
Open please the attached Prime 3.1 sheet with undefined ns and ps ![]()
When I open new sheet - all is ok with ns and ps.
When I open attached sheet - problems with ns and ps.
Found it.
And YES it's a bug...PTC, because even in a CGS system, ps should be allowed (as should 'fs', 'as' and below).
And it's a bug even more because ps is offered from the units table, also when the units system is set to CGS.
What units do not work in CGS?
What is a logic here?
What's the logic in a bug?
