There are of course built-in finance functions within mathcad and excel.
M=240 months is wrong! M is not a time, it has to be just a number (possibly numbering the months).
In the formula for "p.mon" the definition of "m" in the exponent is missing.
Yes, its the numbering/number of the months for which the load was made.
@Werner_E wrote:In the formula for "p.mon" the definition of "m" in the exponent is missing.
From where I took the problem its not written either there. But from my interpretation is like that:
My point was merely that the information is garbage, as is unfortunately very often the case in so-called economic “science”.
If a quantity is dimensionless, then you can't assign a unit to it in the text either.
And if you use a variable “m” in your explanations, then you also have to say what you mean by it.
Simply replacing “m” with a “k” would be too short-sighted, you would just have to express that p.mon is dependent on “m” - in mathematics this is called a function 😉
In the formula for b.k you can then use the running variable k as a function argument.
But actually its just a typo and "m" should be "M" !
See my answer below.
Yes, it think its better to forget this problem. This problem I found somewhere, and it seems to me interesting at first sight as it is related to real life. Think about when someone make a mortgage/load when someone buy a house. But anyway, lets forget about this problem.
As DJF pointed out, mot programs have a built-in function for those kind of calculations.
The scan you showed is sloppily formulated and also contains a typing error (m > M)
But essentially its the correct formula (one can argue about the sign, if the result should be positive or negative).
See my answer here Solved: Re: Total interest paid for a load L(money) over M... - PTC Community
Yes, that corresponds with the formula given if we replace "m" by "M" 🙂
