Unable to plot a function in Prime 3.0
wspier
I'm getting an undefined variable error when trying to plot a pair of functions to draw a circle.
I can however get the individual expressions to plot if I don't use them as part of a function
so Mathcad is able to access all the values.
I'm guessing it has something to do with the way I've used them in the functions.
I have rearranged them a couple of different ways and it will change which variable
it sees as undefined but that is all.
I know there are other ways to draw a circle in Mathcad but this one has it charms for
what will be included in the worksheet later.
Thanks.
RichardJ
(To:wspier)
A couple of problems:
1) You can't use an inline evaluation with a function definition. An inline evaluation displays the value (or values, if an array) assigned to the variable on the LHS of the assignment operator, but values are not assigned to a function definition.
2) You must call the function with the same number of arguments you used when you defined it.
RichardJ
(To:wspier)
wspier
(To:RichardJ)
It was likely the evaluation operator that tripped my up initially.
Thanks a mint Richard.
