I recently downloaded Mathcad Prime 3.0 Express and used it to create a calculation note.
However, I am unable to print my document, paper or pdf. When I do so, I only get a single blank page.
Is it possible to print document with the Express version? Does it work only with the full version?
Thanks for your help!
1. Mathcad Prime 3.0 requires Microsoft .NET Framework 4.0 or later. On Windows 7 client computers, Microsoft .NET Framework 4.0 is enabled by default. On Windows 7 servers, this feature is disabled and you must enable it through "Control Panel" --> "Programs" --> "Turn Windows features on or off".
2. Try to contact with PTC's tech support by using "Mathcad Support Center":
http://www.ptc.com/support/mathcad_supportCenter.htm
http://blogs.ptc.com/2011/09/22/how-to-use-the-brand-new-online-mathcad-support-center/
