I need to recall the unique numbers for an array or vector to remove repeat/dupliate values. This can be easily done using the Excel's unique function. Is there a function in Mathcad or a simple program line to accomplish this?
SLS
Try the Stuart's set function. I adopt it in http://communities.ptc.com/servlet/JiveServlet/download/91267-12172/set.mcd
Can see also http://communities.ptc.com/message/91270#91270, between others post.
Regards. Alvaro.
1.The rotate(n,v) added for its great utility.
2. Drop(V) w/o match applied after rotate(n,v)
jmG
Here's another one, that works for matrices as well as vectrors
Thanks to all who replyed. The examples are excellent and my was question answered.
SLS
