The difference is about 93 kg.
The ton is 1000 lb,
the tonne is 1000 kg.
The ton is 1000 lb,
Last time I looked, 1 ton = 2000 lbs, which is what your formula shows.
Of course, you're right.
I didn't look carefully enough. Fortunately I added the Prime expression.
A US ton = 2000 lbs.
