Units
ptc-1413150
2-Guest
Units
In Mathcad I type R to get degrees rankine, a temperature unit. But spirit is taking it to be the universal gas constant. Must use drop down unit menu to get R as a temperature unit.
Paul
It's a matter of labeling. R is defined as a unit as a degree Rankine and as a constant as the universal gas constant (on a molar basis). Unlabeled, it refers to the constant, not the unit. Attach a label to get whichever you really want.
__________________
� � � � Tom Gutman
Better for degrees Rankine is �R.
We have in Mathcad 14 R and �R as degrees Rankine.
Val
http://twt.mpei.ac.ru/ochkov/v_ochkov.htm
