Unnesting arrays automatically
Raiko
Hi fellow MCers,
is there an automated way to "unnest" an array?
I have a huge amount of excel files from which I read in some data. These are all displayed in a nested array (see attached image). As I have really many files I don't wish to call up every single array element manually.
Raiko
P.S.
I have made a search for this topic beforehand, but the attachements are missing in the relevant posts 😞
FURTHERMORE
Why is it that the time stamps are put into a nested array instead of a "simple" array?
I'm reading in the time line information from Excel files and had hoped to arrange them according to the time differences. However, in order to compute them I need to access the cells of a nested array. Displaying a nested array is fine but doesn't exactly solove my problem.
Any ideas?
Raiko
FDS
(To:Raiko)
Maybe you could try format -> results -> Display Options -> check Expand nested arrays
10 REPLIES 10
FDS
(To:Raiko)
Raiko
(To:FDS)
Hi desomer,
thank you very much - that did the trick. Checking unnest array and displaying said array as a matrix worked fine.
Cheers
Raiko
RichardJ
(To:Raiko)
Your "i" should run from 0 to 16, not 1 to 17 (the origin for al arrays is 0). That's why the first element of your array is a zero.
Change XY[i to XY Ctrl 6 i (column operator). The return the transpose of XY. Your array should then be a vector (I think - I haven't tried it to be certain)
MikeArmstrong
(To:Raiko)
Please post a worksheet if possible.
Mike
Here we go
Raiko
Raiko Milanovic wrote:
Here we go
Raiko
Here, it goes nowhere !
Post a work sheet wherein the results are nested, and don't zip !
You have a folder, what's a folder ? an empty folder,
a folder of what ? If you have data in that folder, put them in a
Mathcad data table. How can we know what has to be unested ?
Vertical nest ? horizontal nest ?
Raiko
(To:jeanGiraud)
Easy Jean !
You've already helped me with your posted gif.
Is there a problem in this forum with attaching a zip file I'm not aware of?
For convenience I've added some Excel files so you can have the results immediately in the work sheet.
Anyhow, you have helped to solve my problem.
Raiko
MikeArmstrong
(To:Raiko)
Here we go
Raiko
Raiko,
Have a look at the attached image.
I have changed the path of the file to suit my works computer, just ignor those changes.
Mike
Message was edited by: MIke Armstrong
You seem to have a simple extract, maybe not done correctly. Lot of Mathcad results come out nested. Sometimes it's possible to unest from the costruct, sometimes it is not or messy.
Raiko
(To:jeanGiraud)
Cher Jean
merci beaucoup pour votre aide
Raiko
