Using Excel Database in MathCAD
jgraham
I've been reading through the forums but I have not found a solution to what I'm looking for. Basically, I need MathCAD 14 to read an Excel database are spit out specific values to be used in calculations.
The excel file is a list of alum. extrusions and their section properties. Below is what I want to do.
Die: 123 <--- This would be the input, the die that I want the properties for to use in the calculation.
I=x.xxx
S=x.xxx        These are the specific properties that would be auto populated based on the excel file.
J=x.xxx
and so on.
I can then use those values in different equations throughout the MathCAD sheet.
The excel file would be arranged with the Die number in column A and the output values in columns B to G (or however many property values that I would need)
Hopefully I described it well enough that someone can point me in the right direction.
(To:jgraham)
You could use READEXCEL to read in the whole Excel table in a Mathcad matrix and the use the built-in "vlookup" function to get the property values as wanted-
Looks pretty straightforward.
WE
(To:jgraham)
The attached file should help.
Put the Excel sheet in the same directory as the Mathcad worksheet.
WE
The files you sent make sense when I look at but it is not working. Not sure if it is able to find the excel file properly. They are both in the same directory. Eventually, I will need this to be accessed by multiple people so the excel file and mathcad worksheet will not be in the same folder.
EDIT:
I'm not sure if Mathcad 14 has ReadExcel function but I used the READFILE function. I also had to save the excel file as 97-2003 xls file as opposed to the xlsx file. It works now, thank you.
