Using Lookup function
- April 8, 2024
- 1 reply
- 1624 views
I need to use lookup function to specify the sand layer . I want to say if the value of qcza is between 5 and 25 MPa then the sand layer is in the depth that gives this range , I tried to do it , but I guess it's wrong
