Hi
The value of sin (1.515) should be 0.026 as per the calculator. THe program however, reports 0.017 (please see attached). Kindly assist.
Sriprakash
You need to put the deg inside the brackets. i.e. sin(1.515deg) not sin(1.515)deg
Many thanks. The values match.
Sriprakash
