Variable Error Check Prime 8.0.0
Snowshoeman
Mathcad 15 would give me an indication that I was reusing a variable.  Prime 8.0 does not give any indication that the variable is used again.  Is there a setting to allow this feature?  See attached.
Raiko
(To:Snowshoeman)
Hi Bob,
check whether the redefinition button is switched ON.
Raiko
Cornel
(To:Snowshoeman)
Why not? See Mathcad Prime 8 file attached.
Snowshoeman
(To:Cornel)
Thank you!
Raiko
(To:Snowshoeman)
Hi Bob,
Raiko
Snowshoeman
(To:Raiko)
Thank You!  It works!
