Hi Frieds,
I want to define two variables A and B:
A=485.193(h6) mm , where "h6" is the tolerance and "mm" is the units
B=420.000(+0.15/-0.10) mm , where "+0.15/-0.10" is the upper and lower tolerance, and "mm" is the units.
Is there anyone knows how to define variable A and B to make them display as following:
Best regards.
Jeffery
The only way I can think of doing it is like below.
Mike
Similarly to Mike's post, please see the attached.
Norm
Nice Norm, I like your +/- mod ![]()
Mike
Unfortunately, I cannot take credit for it. From the old collab, Stuart Bruff if I recall correctly.
Norm
The great Stuart. The amount of worksheets I have which have been created by his is unbelievable. Shame we don't see much of him anymore.
Mike
haha,Than you.
No problem at all Jeffery.
Mike
haha,Than you.
haha,Than you.
haha, Than you Mike.
Nice example Alan. The issue I see is that you now have strings, which would be ok if no further analysis is required.
Mike
Hi Friends,
Thank all of you for your effort in dealing with this problem.
Best reagrds.
Jeffery
Hi Friends,
Best reagrds.
Jeffery
