Vector filling problem
Ian1
7-Bedrock
Heres a little MathCad 15 problem I would welcome some help with - I have spent a couple of days trying to get a MonteCarlo sim to work and have traced the problem to a simple vector filling function
If I pass numbers to a function to put into a vector - the fourth element in the vector becomes a {4,1} sub vector containing the first 3 elements plus a zero. Problem is reproducable and occurs on 64 bit Win 7 and 32 bit XP machines
I have attached a very short worksheet that illustrates the problem
Any thoughts anyone
Ian
MikeArmstrong
(To:Ian1)
Have a look at the attached. You are using d as a argument and then calling it inside the program.
Mike
6 REPLIES 6
MikeArmstrong
(To:Ian1)
Mike
Why bother with the fuction in the first place?
Mike
The Montecarlo funtion needs a function with a vector input - not a list of variables seperated with commas, so I was just tucking all the parameters into a vector - or have I got that wrong too ??
MikeArmstrong
(To:Ian1)
You could simple use the function as shown in this worksheet. Vec has been defined in the collasped area.
Mike
Ian1
7-Bedrock
(To:Ian1)
Mike
Thanks - I have been using MCad for more years than I can remember - I can't believe I made such an elementary mistake and struggled to solve it for almost a day ! Not seeing the wood for the trees.
Thank you for a clear pair of eyes !
Ian
MikeArmstrong
(To:Ian1)
No problem at all. Sometimes it is much harder to find your own mistakes.
Mike
