Where is all legacy Mathcad stuff ( Electronic Books, Add-ons for Mathcad 8, 2000, 2001, 2001i) ?
ptc-2000710
Where is all legacy Mathcad stuff ( Electronic Books, free Add-ons for Mathcad 8, 2000, 2001, 2001i) ?
Much of it was/is loadable even by newer and current Mathcad editions !
I did not find anything here, also Google does not find anything special if I look for "Mathcad Electronics Books".
Btw, I am still using Mathcad2001i - no software activation, enough math power -, for my own internal development purpuses. It runs well on W2k and WinXP.
If an employer or project owner asks me to do something with Mathcad, I expect a current version of course :-), thats the business.
With the newer Mathcad versions, it is still possible to save in the Mathcad 2001i format (but not in Mathcad 2001 format, or older ) :-).
Sincerely
Rolf
33 REPLIES 33
RichardJ
(To:lorth)
Mona is no longer with PTC.
You should statrt by going through the tutorials. In Mathcad 15 they are quite good, and will get you going on all the basics (and more) of Mathcad. I've never looked at the ones in Mathcad Prime, but there are some, so if you haven't done so already you should go through those.
VladimirN
24-Ruby II
(To:lorth)
lorth
(To:VladimirN)
Thanks so much. My next question. I am learning mathcad to docment my learning of calculus. Is there any software to help with illustrating calculus problems? What if I wanted to solve a related rate problem where water is flowing into a drywall mud pan that is shaped like a trapezoidal solid so that it is more narrow at the bottom than at the top but otherwise is similar to a pie pan. I would like to draw and dimension it. Is their software that would allow me to change the length and shape of the pan and have the dimensions reflect those changes. I would like to better visualize what math is saying to me.
Sincerely,
Larry
VladimirN
24-Ruby II
(To:lorth)
To create 2d sketches you can use the integration between Mathcad and SmartSketch (http://www.intergraph.com/products/ppm/smartsketch/default.aspx).
Another useful example of this integration can be found here:
http://communities.ptc.com/message/221356
http://communities.ptc.com/message/221306
http://communities.ptc.com/message/221309
