Hi all. I have a model that calculates heat transfer coefficient. It is supposed to and does most of the time, return a numerical value (an integer) for the heat transfer coefficient. However, sometimes it will return a complex number, e.g. 20 + 5i, instead of an integer. What does i stand for in Mathcad and how can I get the model to return an integer?
As you have surmised, i is the square root of -1, your result is complex.
Two questions:
Hello!
Please, attach your Mathcad worksheet.
Sorry I can't attach the Mathcad worksheet as it contains confidential information but is there any information I can give you which will help?
Need a screenshot showing the problem.
Two questions:
Why integer!?
It is a real value - see http://en.wikipedia.org/wiki/Heat_transfer_coefficient
I agree it should be real. But it shouldn't have to be an integer!
Somtime it can by integer, by the rounding for example ![]()
In Mathcad MM we can switch off the calculation with complex numbers.
In this case we get not a complex number but an erroe message and can trace this error
I've found the source of the problem thanks
